crankyfranky
working on my new to me 1963/4 ford 2000 4 cyl tractor and the battery is installed with the negative ground. the coil is also installed for a negative ground system so i think the previous owner may have converted the tractor from Positive to Negative ground for some reason. the charging system appears to be in good condition but isn't charging. the tractor has sat for many many years with a dead battery and probably needs flashed. but since the previous owner passed away many years ago i can't ask him what he was up to and have to figure it out. my question is was there a different voltage regulator for a negative ground system or will the original work either way. my regulator appears to be new and is the three terminal type with field/arm/batt connections. before i proceed to flash the armature to the battery is there anything i need to consider???? Thanks
