My first tractor so lots to learn. When the key is in the spring loaded start position the lights on the control panel go out and the starter is silent. I changed out the key switch...then the voltage regulator... then bypassed the safety starter switch...no change. Found a bare end hot black wire under the dash next the a relay unit which is hanging to the left of the steering wheel below the key switch that I can't find on the wiring diagram in the manual. So how do I remove the sheet metal cover that the key starter switch screws into to gain access to the wiring to see what that loose wire came off, why is there a relay unit by the key switch and what else can cause everything to loose power with the key turned to on? Thanks.
