Company Logo Shop Now
Order Ford 860 Parts Online
Help connecting 3pt auger to Ford 860 PTO
WV860
07-12-2020 11:29:35
Have a 1955 Ford 860 & a 3pt auger. It has a driveshaft connected to the gearbox that terminates with square steel tube. Question, what would need to complete the connection?
Also, would a clutch protect the PTO shaft?
sotxbill
07-13-2020 05:42:07
 Re: Help connecting 3pt auger to Ford 860 PTO in reply to WV860, 07-12-2020 11:29:35
If the phd was already there, look for the front half of the pto shaft.
measure the shaft dimensions so see what a front half cost. ie the shaft could be 3/4" by 1" rectangular,, or 1'x1' square. the front shaft can slide over if the rear shaft is solid,, or if the rear shaft is hollow, the front shaft can slide inside. That will help you know what your looking for.
If not, remember you can buy a whole pto shaft for a phd for around $150 + or - delivered, off of ebay, so dont go to a farm store and pay 350 for a half shaft. (https://www.ebay.com/itm/New-Post-Hole-Digger-PTO-Shaft-Heavy-Duty-Series-4-1-1-4-Smooth-Bore-Yoke/261865878952?hash=item3cf86c35a8:g:F8sAAOSwBahVO6hA) but you have to match up where the shaft comes out of the gear box. Most phd's have the same size input shaft.
Secondly... remember.. a phd is about the only implement that you use on the tractor.... that the pto speed should be just above an idle... That way if it hits a root, water pipe, it will kill the engine. Otherwise... it will screw itself into the ground, with the roots holding it,, and you will be three weeks digging it back out. Lots of new diggers have a max tractor rpm of 1000 on them. about everything else off the pto, the tractor must be at pto speed for them to work.
Hope you find the other half of the shaft.
RayJohnson
07-13-2020 05:23:34
and can be screwed in the ground.. :)
showcrop
07-12-2020 18:51:58
You need a square shaft that slides into the tube connected by a universal joint to a PTO coupler. Pretty much all farm supply stores have a display of PTO shafts and parts. There are just a few different types on many different implements.
WV860
07-12-2020 13:59:53
Gotcha, thx for the post. Being new makes it challenging to say the least.
denny k
07-12-2020 14:11:19
 Re: Help connecting 3pt auger to Ford 860 PTO in reply to WV860, 07-12-2020 13:59:53
Just remember a post hole auger CAN be a dangerous piece of equipment to operate if you are not careful.
Ultradog MN
07-12-2020 12:22:25
To affirm what Jmor said but in different words, you need the other/front half of the driveline. If you mean do you need an over running clutch to use an auger, no you do not. Your 860 has live PTO so you don't need an over running clutch for any implement.
WV860
07-12-2020 12:16:16
Id like to run a clutch to protect the PTO output shaft. Not sure what to use (style & size)?
JMOR
07-12-2020 11:49:46
Quoting Removed, click Modern View to seeAnother, larger square tube with s u-joint (to fit tractor pto splines) which slides over the existing tube, assuming that existing tube has u-joint at gear box.
WV860
07-12-2020 11:33:22
Also, as you can tell, Im new to tractors. Just looking to keep up the tradition on my wifes family farm.
Copyright © 1997-2020 Yesterday's Tractor Co.
