Company Logo Shop Now
Hot Climate Engine Oil
fredbollinger8807
07-11-2020 17:26:19
Would anyone have a suggestion on which oil would be best to use for my 1940 Ford 9N tractor? I am in south Central Texas and the Temps have been running in the 100's! Also I am over heating it since it has a pusher fan which I plan on fixing, but I am wondering if anyone has any thoughts on increasing to a 13 psi radiator cap?
David G
07-13-2020 14:51:37
 Re: Hot Climate Engine Oil in reply to fredbollinger8807, 07-11-2020 17:26:19
4 PSI is 224 degrees, 13 PSI is 245 degrees, 4 PSI is plenty.
ernied
07-13-2020 09:02:36
Insure the ignition timing is spot on, too little advance will overload cooling.
Check carb mixture, too lean will overheat.
Washout the air side of the radiator core.
blackhole49
07-13-2020 07:54:41
I run 20w50 in my very tired 8n (90psi compression). My oil pressure is 37 cold, 27 hot mowing (72" finish). Been mowing 2 acres in 95* (SE MI) heat the last few weeks with no overheating issues. My radiator was replaced with alum.from China 7 years ago and it has never had a thermostat in the 20 years I've owned it. Before I replaced the fan, I would add a shroud. I would also run it at pto speed, never any slower. You could also try flushing with 50/50 mix of vinegar and water and getting it good and hot. In my mind you are not moving enough coolant thru it for it to boil over.
fredbollinger8807
07-12-2020 17:00:40
As I said earlier Yes it is boiling over, not just releasing excess liquid.
showcrop
07-12-2020 15:04:05
Fred, Shaun is intending to ask you if your N is indeed boiling over or is it just pushing a little coolant out. This is a valid question because as he states a cooling system is full when there is approx. 1/4 inch over the tops of the tubes. If it is filled to the top or nearly so, it will push the excess out as the coolant expands, without actually overheating.
Shaun Wallace
07-12-2020 12:19:32
The coolant need to have 1 1/2-2 inch below neck not jam full.
showcrop
07-12-2020 12:04:12
If you have no fan shroud make that your highest priority item. It will dramatically increase the amount of air drawn THROUGH the radiator.
Dean
07-12-2020 15:18:22
 Re: Hot Climate Engine Oil in reply to showcrop, 07-12-2020 12:04:12
Bingo.
Needs a fan shroud.
Such was not mentioned in the OP.
Dean
Check Break
07-12-2020 10:09:00
This video addresses a lot of issues that have arisen over the years with respect to radiator boil over from a perspective that's not unrelated to your 9N.
https://www.youtube.com/watch?v=Ug01EW7UZGM
fredbollinger8807
07-12-2020 08:19:29
Yes it is boiling over. The core is not clogged with debris and is still in good shape. I have a 4 psi cap and was running 50/50 until it boiled over again. Thank you all for the advice on the Oil to everyone. The Tractor has little oil pressure when at idle and only comes up to about 10 psi at full throttle.
I got this 9N about a month ago when the temps were only in the 90's and it would run much longer before over heating, may be a couple of hours. I am running a 5' brushhog at about half to 3/4 throttle in 1st gear. I know that this tractor was originally a no pressure system which lends itself to overheating in hot climates, and I know that the more pressure you put on the cooling system the less likely you are to boil off. I know this from having worked in the Boiler Rooms of a Cruiser while in the Navy. That was a 1200 psi plant.
So with all that in mind does anyone have any idea what might happen if I did increase to a 13 psi cap strictly as a theoretical question?
I think my best bet is going to be switching the fan from a pusher to a puller, installing a fan shroud, checking for the presents of a thermostat, and keeping it at a 4 psi system with a 50/50 coolant mix.
Thank everyone for their advise and insight.
MarkB_MI
07-12-2020 11:00:57
 Re: Hot Climate Engine Oil in reply to fredbollinger8807, 07-12-2020 08:19:29
A five foot brush hog would be asking quite a lot from your 9N if it was new. It sounds like yours is pretty tired, and it may not be up to the task.
Well, assuming your hoses are in good shape it should be fine. Your new radiator ought to be able to handle the pressure. Going from a 4 psi cap to 13 psi would raise the boiling point of a 50/50 antifreeze mix from about 235F to 260F. My guess is that your tractor will still boil over at the higher pressure. And the more pressure on your cooling system the greater the chance of blowing a gasket somewhere.
Check Break
07-12-2020 07:41:20
A full synthetic oil will handle higher temps better than a conventional oil. You may want to look for one rated for gasoline engines but I'll confess to running diesel rated oil in my 5.4 Ford for 150,000 miles. The biggest problem you will have is a good synthetic will break down the carbon deposits inside your engine and turn your oil black, causing you to change it every year.
Dean
07-12-2020 07:31:48
It's not the pusher fan.
No to pressurized cap.
New radiator? Flat-finned industrial core? If not, debris wil clog the core within minutes when mowing, even with a pusher fan.
Overheating? Boiling or simply pushinig some water out after expansion?
Dean
showcrop
07-12-2020 05:38:36
By overheating do you mean boiling over?
Jim.ME
07-12-2020 04:50:10
No on a 13 pound cap, it wasn't designed for that. I might try a 4 pound but that would be it. It is possible the new radiator doesn't have the cooling capacity of the old one. Also as has been mentioned there could be an issue with the thermostat.
Jim.ME
07-12-2020 04:45:26
A good quality 15W40 diesel oil should be fine.
MarkB_MI
07-12-2020 03:40:51
What are you doing with your 9N when it boils over? If you're plowing or mowing heavy weeds, maybe you just need to slow down or use different equipment. Your tractor was only rated at 13 drawbar horsepower when new; you just can't expect too much out of it.
Now if it overheats under light load (e.g. just driving down the road), then something is wrong. Changing the radiator cap isn't a good idea because the cooling system wasn't designed to handle 13 psi. I assume you're running a 50/50 antifreeze mix; if you're running straight water it should help to add antifreeze.
As for oil, today's oils are far better than what was available back in the forties. Most folks like the 15W-40 diesel-rated oils such as Rotella Delo or Delvac. These are available in conventional, semi-synthetic and full-synthetic versions; switching to a full-synthetic oil might help your overheating problem, but I doubt it.
Ultradog MN
07-12-2020 04:31:34
 Re: Hot Climate Engine Oil in reply to MarkB_MI, 07-12-2020 03:40:51
Small point but let's give the tractor its due. Nebraska Test #339 says 16.39 drawbar HP.
Shaun Wallace
07-11-2020 19:31:05
Pusher fan has nothing to do about getting hot. Look for clogged fins and plugged tubes. If has orignal rad it was not a pressure system. How much dirt and rust in block? Is there a thermostat in top radiator hose ? Is there a shroud on rad?
fredbollinger8807
07-11-2020 19:40:28
 Re: Hot Climate Engine Oil in reply to Shaun Wallace, 07-11-2020 19:31:05
Its a brand new Radiator as for if there is a thermostat I do not know as I did not install the radiator I will have to check. I have researched and the pusher fan pulls heat from the engine over the radiator so it can not get as cool as it should. Replacing it with a puller fan will help keep it cooler as has been proven many times. This conversation does not answer my question about a good hot climate oil.
Copyright © 1997-2020 Yesterday's Tractor Co.
