marcusmerritt
Ford 2000; 3 cyl. Diesel; 8/2 trans.....In an effort to promote marital bliss, I have been digging up ground for a large dahlia bed for my spousal unit. Hard, rocky digging so far, lots of fist size rocks, some larger. I was thinking this was a great opportunity to use my new-to-me auger to drill several holes in the bed so I can dig more easily with a shovel. I've not used the auger before so am wondering if I drop it to the ground and then turn on the pto or turn it on before contacting the ground? I have some 'starter' holes that I can set the auger in so it doesn't dance around. And, I'd try to take small bites at a time, lifting the auger so it doesn't drill itself into the ground. Does the pto work best at 540 rpm's or can I go slower with the auger?
I'd appreciate any insight you can share. Thanks.
