401 injection pump tachometer
ford401
Does anyone know where I can find the little plastic piece that fits in the cone where the tach cable goes into the injection pump?
I don't know Where you would get that except that I think that a diesel injection shop would be a lot more likely than Fiat. You don't need it anyway since your tractor is much too good looking to risk scratching or getting dirty.
Yes I believe that it is 145. I searched for it everywhere online and wasn’t able to find it anywhere. I guess I’ll have to try calling NH today.
Lol thank you. Just finished the restoration, trying to button up all the
little leaks and other odds and ends.
I ran across the same problem around 20 years back and I cant remember exactly what the key I used, but here are some that come to mind...
https://www.ebay.com/itm/GM-Cars-Speedometer-Cable-Adapter-Plastic-Key-Female-GM-88961013-/331379419165 this key converts a big square hole to a standard hole.
or https://www.google.com/search?client=firefox-b-1-d&q=speedometer+cable+adapter+key&sa=X&ved=2ahUKEwiUodSkosrqAhVPXKwKHf-0CIcQ1QIoA3oECAwQBA&biw=1274&bih=1046
However you may need the one with the "tang" on one end and the square female on the other. Dang, its been too many years ago, and too many tractors.
