I just got my Ford 860 back together. Getting good oil pressure at the gauge (45-50 psi @ 1/2 throttle). At almost full throttle, there is only a few drops of oil coming out of the drain-back tube at the rocker arms. Nothing from the pee holes on each rocker. I'm worried to keep running it till I figure out if there is a blockage and if it can be cleared. I would have expected some oil dripping and running along the length of the rocker arm assembly, but nothing! I did try to blow back through the feed tube, but couldn't get any air to go backwards through. (maybe I shouldn't be able to?). Is there a process I can use to verify the oil passages are open? I did install a new grommet on the end of the feed tube and it is firmly seated into the block. Any insight or root cause process would be much appreciated.
Thanks
Thanks
