Company Logo Shop Now
Ford 545D with 4360 cab
Ezgoin2578
07-07-2020 12:36:52
I have a 545D that runs great and is very usefull for what I need, however the cab is very rough, glass is all gone and harness has been field repaired beyond renewal, Ive been shopping for a complete cab without much luck finding a good one( for less than 5000) however I did run across a decent deal on a 4360 with torn down motor and bad trans with what looks to be the exact same cab but Im not 100% that it will mount or that the harness will plug in. I know the shuttle harness would need to be wired outside the harness due to 4360 not being torque converter shuttle but will all else adapt?
Ezgoin2578
07-08-2020 19:44:49
 Re: Ford 545D with 4360 cab in reply to Ezgoin2578, 07-07-2020 12:36:52
I got what your saying, and after looking closely it appears the loader uprights would interfere with the cab because the 4630 cab goes much further in front of the rear axle than the 545 does and the 545 cab just clears the loader frame.
Ezgoin2578
07-08-2020 19:22:12
The 545d loader Frame is all outside of the cab except handle that comes through floor
Destroked 450
07-08-2020 15:30:22
Didn't look that up but you might want to look at where the loader frame sticks up to make sure there's room for it on the ag cab.
Quick search shows the roofs are different and the shifter floor plate is different, mounts are also different.
Ezgoin2578
07-08-2020 11:32:36
Thats what I figured, but wasnt sure because microfiche is showing different part number for cab frame.
Destroked 450
07-08-2020 10:11:06
545D is a industrial version of the 4630 ag tractor, cabs should be the same for a utility model, backhoe cab is different.
Ezgoin2578
07-07-2020 12:47:28
actually its a 4630 that I plan on buying for the cab.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
