1963 ford 4000 hyd pump no pressure
3 pt will not raise ,removed plug on top of hyd pump,no oil comes out with engine running removed hyd pump and disassembled , cant see any thing defective in pump assembly, is it possible for the steel balls to stick on the suction side of the pump, tractor has been setting for 5 years,just rebuilt engine and got it started and no hyd from pump
Maybe a dumb question . . . but have you got Hydraulic oil in your center housing (hydraulic reservoir)?
