FarmMan2600
I have a 5610 Ford that I use to cut hay. The Hydraulic lump
makes a significant whining noise while cutting. It gets quieter
when I use one of the hyd remotes. It doesn’t have the engine
mounted pump and It isn’t as noticeable at an idle. I’ve only
had the tractor a little over a year and it has always done it,
but has seemed to get worse. I’ve always thought the
hydraulics were a little weak, but not terrible. It may be time
for a pump, but wasn’t sure if the problem could be elsewhere
like the priority valve or if this was just the nature of the beast.
Any help is appreciated. Thanks.
