Chris_in_Texas
Hi All, as mentioned in my last post I recently got my hands on my FIL's old Ford 4630. I am working on tracking all of the major leaks down to get the tractor ready to use on my property. Right now I am focusing on the Flow Control tube between the Flow Control and the pump. Looking at some exploded diagrams I can see the tube and an o-ring in the pump for the tube but when I run the tractor and the FEL I see the fluid is actually running down the tube from the Flow Control and not up from the pump, you can kind of see this in the pic where the entire tube is covered in oil and not just the base. This leads me to believe that the issue is not with the o-ring in the pump but is something else in the flow control valve. In my other post Destroked 450 pointed out that I am missing the Snap Ring on the tube. Is it possible that the lack of snap ring has allowed the tube to creep down preventing proper seal in the valve allowing fluid to flow from the valve?
If the issue is with the tube, snap ring and o-ring is there anything I need to know about replacing the tube? Does the Flow Control valve have to be removed or is there play in the tube to lift and replace the o-ring? This will help me in knowing what I need to purchase in addition to just an o-ring (i.e. Gaskets, other O-rings affected by the removal)
