Removing pin holding radius arm to the front axle on a Ford
FarmerHR
I would like to remove the pin holding the radius arm to the front axle on a Ford NAA. Think the pin has a tapper that is in the top of the yoke.
Could anyone give me some suggestions on how to remove this pin without destroying anything ?
Thank you for your help in advance.
(quoted from post at 06:29:47 06/29/20) I would like to remove the pin holding the radius arm to the front axle on a Ford NAA. Think the pin has a tapper that is in the top of the yoke.
Here is the discussion?
https://forums.yesterdaystractors.com/viewtopic.php?t=1434173&sid=9a548db40268500cface9219596d643c
