861D Injector Pump Timing
Ranger63
New User
I am replacing the seals in my injector pump and am confused about the proper timing. The tractor manual I have says 18 deg btdc and the diesel supplement manual says 23 deg. Does anyone know which is correct and why there are two different numbers listed out there?
Early pumps with no delivery valve were set at 18 degrees, late pumps with delivery valve were set at 23. Try both if you like, see what engine likes best. DO NOT ADJUST PUMP TIMING WHILE ENGINE IS RUNNING!
