Ford Tractors Discussion Forum |
4600 Injector pump
Author |
[Modern View] |
Bill Mack
06-16-2020 17:54:39
I'm trying to bleed the fuel system on my 4600. I get fuel at the bleeder screw when I turn the key, but no fuel at the injector lines. I know this might simply mean a faulty pump, but I don't have a lot of experience and was wondering if I might be missing something, of if there is something I can check or try.
Thanks
Bill Mack
06-19-2020 15:10:56
Re: 4600 Injector pump in reply to Bill Mack, 06-16-2020 17:54:39
Hi Dieseltech. I sent you an email.
nashranch
06-17-2020 19:36:42
Bill Mack
06-17-2020 08:38:38
I saw another thread on here that said if I cut the wire connecting two bolts on top and remove them, I can loosen the metering valve. Sound right?
Dieseltech
06-17-2020 12:55:31
Re: 4600 Injector pump in reply to Bill Mack, 06-17-2020 08:38:38
Yup, but that won't free stuck rotor plungers..
Bill Mack
06-17-2020 04:49:55
I've checked the kill cable and it's OK. I'm fairly mechanically inclined, just inexperienced with tractors, so I'm good with trying to fix whatever I can. Looks like new injector pumps are $500+ so I don't have much to lose in trying. Do I need to remove the pump?
The tractor hasn't run in over a year.
Dieseltech
06-17-2020 07:57:18
Re: 4600 Injector pump in reply to Bill Mack, 06-17-2020 04:49:55
I repair 3-4 pumps each month with stuck internal parts from setting, usually water in fuel or bio diesel is the problem. Long as the hydraulic head is not seized or severely worn the original pump can be repaired for less than a new China pump..
Dieseltech
06-16-2020 19:55:08
What Bern said.. When did engine run last? If it's been awhile you may have more internal parts like rotor plungers stuck too along with the metering valve, requiring a complete tear down and cleaning to free everything up again. Have a Ford 172 pump apart now for the same trouble..
Bern
06-16-2020 18:48:47
Either your kill cable slipped and the shutoff valve is in the off position, or else your internal metering valve is stuck in the off position. The latter is a simple fix if you've done it before, and maybe a little overwhelming if you're not mechanically inclined.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
need 3 point arms (with the ball) especially need the
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
