My 600 takes lots of cranking to start after sitting overnight but then
it starts on first crank everytime the rest of the day! When it finally
starts it blurts lots of black smoke likely since I over choked it in
frustration.
I had this problem some time ago and traced the problem to
sticking valves after removing hood and valve cover. I could see the
valve slowly returning to the rocker arm. I hit it with solvent and
freed it up but now the problem has returned and I hate to have to
remove hood and valve cover! Anyone here have this happen?
I plan to change the oil to a lower viscosity oil and try some
additives to the gas and oil both to loosen up the valves.
frustration.
