Ford 2000 hydraulic trans oil....some people..
Britcheflee
Some people should not be allowed to own equipment...so checked trans/hydraulic oil and its mocha coffee - I am draining at the moment - if I let it sit for a while will enough drain out so I can just refill or do I need to fill, run and drain again? See sad picture..
OK great - might not get so much condensation here in California - going to change rear hydro oil too which is in reasonable condition - will run some of that in transmission case to see if I can flush out some of that milk.
That's just the way it is with today's super oils. The additives cause the oil to grab and hold onto moisture much more than the oils that were used when the tractor was new. When tractors and other machines are being run hard for hours weekly the condensation always gets driven off by heat. If they get only light use the moisture builds up.
