2wheelgnnr
I have a jubilee and my 3 point does lift as high as it used to. My previous 8n lifted highter too. with a dirt scoop or carry all on it.....the 3pt lifts about 6"-8" off the ground. thats it. how get the lift back that I used to have.
Ie tried to move the position control quandrant back all the way to maximuze lift..that im aware of...but any other way to get more lift out of it. at 6-8" I cant even lift it enough to dump the dirt scoop?
What can I do to get more lift out of it. I have a pic I will post later. Thank you all for any advice. It even used to lift higher just a couple of weeks ago....and all of a sudden it does not. I will work on seeing if any air in system but I need to be careful as the air screw on the vane pump is on awfully tight...and the system is full with Hydraulic fluid I checked that too so far.
