Ford 3000 1974 sos Transmission Screen filter
markwolumla
New User
Could someone tell me where I can buy Ford 3000 1974 sos transmission screen filter ,, item no 22 in attached picture. It is part no 312283 in New Holland parts list. It comes up as discontinued . I contacted Messicks , (email), and they said they could not find an aftermarket alternative .
As it would be a least 30 years since this filter has been replaced ,,, is it a filter that could be cleaned and re installed ????
Thanks.
Part 22 in that diagram is a metal inlet screen, and it is meant to be cleaned and re-used. The other part number you have circled, 25, is a pleated paper cartridge type filter which is meant to be replaced. It is part number 309735, which is still available from New Holland, and that part number includes the filter and the gasket.
You will not find any source for a new suction strainer.
You will need to search salvage yards for a good used one.
Dean
Thanks for your replies,
Have been searching the internet regarding info/availability on this Screen filter with no luck , only whats in the manuals. Hopefully it is not damaged in any way.. If not I will clean it up in diesel /kerosene and re install...
I have ordered the Wix aftermarket transmission filter, (item 25 in picture), so all good there... I was thinking about the hydraulic filters , (under the top cover), but as the hydraulics are operating ok, I will leave that job , as it seems to be out of my mechanical range .....
Cheers...
Mark, you are complicating the issue by referring to a "screen filter" because your transmission does not have one. It has a screen and it has a filter. They are entirely different.
Snowcrop,
Yes the item 22,(screen), is described many ways. Picture is from manual. Unfortunately the term filter is added to most descriptions.
