Ford 600 issue
My ford 600 has had this issue for a long time and I can’t figure out what it is, so here it goes the left side tire in whatever position it is pointing has a lot of play back and fourth and from the looks of it, it’s in the steering box somewhere, any clue, thanks. The back and fourth movement is about 2 and half inches.
Also the other thing is that when turning in either direction the front tires always dig in the ground pretty good so if y’all have any clue about that the tires on the front are 6.00-16 and the tears are 13.8-28
You need to jack up the front end and see if your spindle bushings and bottom spindle bearing are shot. Any slop you take out of whole steering system is better for all parts of it. Check your wheel bearings also.
I checked both because the spindle bearing was gone and while I was there I checked the spindle for wear along with the bushings and they were both fine the new spindle bearings made little difference
