Re: Just wanted to share what I've decided on.
sotxbill
05-25-2020 06:52:46
Would pressure check the remotes for over 2000 lbs. Buy a 3000lb filled gauge and put a hydraulic nipple on it...
also, can change hyd cyls to larger diameter so that they will pick up more weight, but operate a bit slower. Cant see the cyls in the picture but I assume they are 2 inch which will be small for that application?
Extend the mounting point of the wing hyd cyl mount,,, to give more leverage to the cyl... as the first part of the lift is the heaviest, as the wings come up, the weight is transferred to the hinges and they get lighter.
