Order Ford 600 Parts Online
Re: brake shoes and fuel tank valve for 600
Dean
05-25-2020 05:48:24
I know of no reliable source for hundred series fuel valves but I have had better luck with valves bought from CNH.
Yes, I too have had weak brake issues even after installing new relined shoes, turning the drums and eccentric grinding the shoes to fit. Inspect the cam ends of the brake actuating shafts and the corresponding wear points on the relined shoes. A little bit of wear on either reduces mechanical advantage significantly. These days, most of the relined shoes have been relined so many times that the steel wear points are badly worn.
Dean
