600 won't go into gear
geraint
New User
I have a 57 Ford 600 that will not go into any gear while it is running,you turn it off it goes right into any gear.I need a little help figuring this out .
Thanks
Either the clutch is dragging or the pilot bearing is sticking to the input shaft causing the trans to spin when the clutch is depressed.. Look at the linkage outside of the transmission case, I check this everytime , look for the "ear" on the clutch linkage the the "ear is twisted and pulled apart from the cross shaft. Otherwise the only fix is to split the tractor and repair the clutch or pilot bearing problem .
IF it is simply a stuck clutch (perhaps from sitting long time) then start it in gear and drive it herky jerkk, slamming throttle back & forth and I have broke them lose this way more than once. Need open area so as not to run over anyone or anything!!!!
