1910 electric problem
My neighbor has 1910 tractor, started drove out of shop and shut it off. Now there is no power beyond the key switch. tried jumping across hot post on switch to solenoid wire, nothing!With switch in the run position there is no power to any other posts. What's wrong, is switch bad?
I would check the battery posts first. Make sure they are clean and making full contact. Then if you are getting juice to the switch but not threw it, then replace it.
Check your fusible link near the starter. It hooks up to the same post as the positive battery cable, and is responsible for powering up pretty much the entire electrical system.
