RE:ford 1720 4wd
dpendzic
I removed the 4wd gear box off the transmission and have a bad idler gear--having trouble finding another one
part # sba 322323480
thanks
Try Raffi in West Linn, Oregon. Five 0 Three 63 eight 19three nine. That is his shop number and he will ship.
Once you find a replacement and get it installed, be very careful about how you shift it into 4WD, or you'll be doing it again down the road. That is not normal wear.
What does the mating gear look like?
I would try Long Lane Tractor in elizabeth town PA. He has a lot of Fords he parts out I got parts for my 1710 there. there's also a place called weaver's compact tractor parts i believe their website is external_link.com i've gotten stuff from them to.
the mating gear is not as bad--but i'm told you have to split the tractor and pull the transmission to change that gear out??
thanks but neither one had any gear nor whole gearbox---running out of salvage yards to try--can a machine shop rebuild up these broken teeth??
Thanks---Dan
i'm not sure what they would charge for that gear but we use a company called stine gear out of NC for work. you send them a gear they copy it and send back a new gear with part # on it incase you ever need a
replacement.
