David Adams
New User
I have a Diesel Ford 3000 (force),
The tractor needs ether to start every time it's started from cold. I have ordered a heater plug that will screw into the blank on the inlet manifold, copper pipe & an ignition that will allow the heater to be operated.
I am intending to take the Diesel supply from the hoses between the injectors.
My question is will I just have to run a single wire to the starter key switch and job done or is their any further wiring requirement, ie, fun required etc.
Can anyone supply a wiring diagram showing the configuration?
Kindest regards
Dave
Kindest regards
Dave
