If someone could help me make a positive ID that would be awesome!
There is also an issue or two with the SOS that I could use help with.
When you put it in reverse, it wants to go forward until you let the inching pedal up.
Then it goes backwards as it should, Park works fine. All other gears work fine.
Secondary, the PTO shaft spins constantly and the cable is froze up.
Cable is in the "in" position and it won't move.
It also does not have a posi-traction lock on the rear axle.
