2wheelgnnr
I have a 53 Jube. Let me give the event leading to no lift
Never had issues before this...
Day 1 lifts all the way / full movement
Day 2 Lifts 3/4 of the full movement
Day 3 No lift at all??
Hydraulic fluid full? Ensured did get put into draft control..
Just no longer lifts. Lifted "strong" day 1??
I will try to see if and purge any air out of vane Hyd Pump but if no air what should I do next or look for with inspection plate off???
Thank you for any guidance/advise
OTHER THAN to give the tractor to you!!!!!
