Ford Jubilee 3pt Wont lift troubleshooting
I have a 53 Jube. Let me give the event leading to no lift
Never had issues before this...
Day 1 lifts all the way / full movement
Day 2 Lifts 3/4 of the full movement
Day 3 No lift at all??
Hydraulic fluid full? Ensured did get put into draft control..
Just no longer lifts. Lifted "strong" day 1??
I will try to see if and purge any air out of vane Hyd Pump but if no air what should I do next or look for with inspection plate off???
Thank you for any guidance/advise
OTHER THAN to give the tractor to you!!!!!
Assuming priming the pump didn't help which I doubt, with the inspection plate off, I would look for oil streaming from above or swirling or gurgling in the sump. I sounds like a valve has gotten sticky. Come back with your findings.
Will do I hope to get some time to work on tonight as weather is looking like it may hold out her in Western NY finally.
not sure what happened..I started tractor last night.....when to get the tools to let out any air that may be in the vane pump and while gone 3 pt was lifted..... so it started workiing again....after letting it run for 5 min or so... shut off..
started back up started working right away again?? pump must of lost prime and then got it back with just letting it run. Hmmm
Can I adjust it to lift it a little higher? I thought there was a way on my 8n and I think it was by loosening the square block that had the positiion control lever on it and moving towards back end of tactor a bit...not that the pos control had alot of side to side movement but a little bit and it worked. can I do that On a jube. it just does quick go as hight as it should so to speak or my other tractor did......thanks
(quoted from post at 10:08:55 05/21/20) not sure what happened..I started tractor last night.....when to get the tools to let out any air that may be in the vane pump and while gone 3 pt was lifted..... so it started workiing again....after letting it run for 5 min or so... shut off..
es, you can slide the quadrant.
