Ford 3000 Holley carb questions
mikewood869
Does it really matter on what repair you get for these carbs. I think this model is a r4111-10 or am I off on the model. Got a repair kit for a r4119, 20 and other models (1965 - 1975, 2000, 3000). I think the other one I have is a r4336 too. Anyway, it came with a needle and some other things, but just needed the main gasket to put the two half s together. I m assuming I can pull the jet from a zenith 3 cylinder 4000 carb and put in the Holley.
Yes, it very well may.
Metering plate gaskets, float bowl gaskets, etc., vary
In order to get the correct (expensive) kit from CNH you must take both tractor and carburetor serial numbers to your CNH dealer so that they can order the proper one.
BTDT.
Dean
