800 shift too stiff
Jim TN
What does it take to fix a 800 shifter so that it will go up and down easy. I even put a grease fitting on mine and it didn't help.
I have two with the up and down five speed. They work with no resistance what-so-ever. You will need to remove the cover and find where the resistance is. Be sure not to loose the key.
There is an interlock plate that slides on a rod inside the transmission. Something is amiss with the sliding action. Will probably take a transmission teardown to repair it. Sorry for the bearer of bad news
