Ford 340 (A,B,C) shift lever dust cap alternative
HD_Jeff
Searching online, I'm not seeing this dust / weather cap available, and will check with the dealer in the upcoming days, but I need to replace those dome shaped covers which also support the spring providing slight upward pressure on the shift levers.
Have you found a part or alternative?
I guess you mean the spring retainers? They are not really dust covers but they support the base of the compression springs and keep them centered. The part number is 82007346. messicks.com has them in stock and wants $14.05 a piece. partspring.com also has them in stock, but they only sell them in bags of 5 for $66.25, so they're aboyt 70 cents less per from partspring, but you have to buy more than you need. You should be able to get them from your local New Holland dealer if you have one for around the same price and skip the shipping charges.
retainer on partspring.com
retainer on messicks.com
Sean, thanks for the fast reply. Yep, thats the item. I did a few searches with the part number and found similar prices. Pack of 5? Now thats just silly.
Again, much appreciated.
