3600 aux hydraulic hose connection
poppy741
New User
I have a 3600 and the hoses from aux hyd output to the front end loader controls need to be replaced. The problem is, I can't for the life of me figure how to disconnect the hoses from the aux output. Anyone have the magic formula to get these things loose?
I can't say for sure as I haven't seen
one of those but I would remove the 2
bolts that hold that aluminum block down.
I'll bet it splits in half (top and
bottom halves) and you can get at the
quick connects inside it.
Douse the 2 bolts good with penetrating
oil for a day before you put a wrench to
them.
Would be interesting to see a follow up
post on what you find.
Quick disconnect couplings, once you lower the loader and relive all of the pressure you should be able the yank on the lines and pop them out. This is providing the balls in the coupler haven't rusted and became stuck.
There is no pressure on the hoses....they are disconnected from the loader. But I can't get these things to budge. i'll try a little kroil or blaster and see if that loosens them up. Thanks for your input.
