3000 3 cylinder trans -rearend level check locations
tn terry t
I had a young man help me remove the rear axle because it was pouring oil of the bad seal. can you guys please tell me where the transmission and rear differential oil fill level is on these tractors I getting pretty crippled up and its awful hard on me to get down there and look thank you
Trans and axle check plugs on a 3000 with 8 spd trans are on the right side by the foot board.
man I should have hobbled down there and look before I bothered you sir I haven't been on the tractor in two years thank you so much !!!!
