Ford 3600 steering
KYCASE1
I am wanting to put power steering on my 3600 diesel with a loader. All of the after market kit that I can fine say not to use with loader. Does any body make a kit to use with a loader? Any help would be appreciated. Thanks
I would check the tractor salvage yards, for a factory system, pump, steering box, and cylinders. Lines too if they are available.
The OEM PS on a 3000 is the same as yours.
I wanted it on mine so bought a 3000 with bad SOS and parted it out. After all was said and done I got the PS cheap, nearly free.
Complete PS for one of those will run you most of a grand from a private party here.
None of the aftermarket kits are designed to work with a loader.
Loader doesn't get in the way, the added weight puts to much stress on the aftermarket drop arms and drag link going under the engine.
Find a factory PS from a salvage 2/3000, 26/3600, may cost a little more but well worth it.
(quoted from post at 11:18:07 05/16/20)
Or better yet, find a salvage 3400 or 335 and transfer the entire front axle and steering from it.
