I have PS fluid leaking from the weep hole on the steering box right above the 4 bolt flange where the steering column bolts to the lower section of the steering box. In the parts breakdown i see a #18 on shaft #24. Could that be my problem??
https://partstore.agriculture.newho...ts-search.html#epc::mr50698ar258902bi25321-1A
This all started when i noticed the power steering didn't work and i checked the resevoir and it was low so i added ATF. The PS did work great for a bit till it started leaking.
What's your diagnosis?
Was ATF the wrong thing to put in the resevoir?
