TW30 Dual Power tool 7402
So I have this TW30 split to put new clutches in the Dual Power and the service manual calls for a tool to align the suction tube. So that when the transmission case is bolted to the rear end center section the tube will be lined up. It has an oring on it and is just held in place with one 3/8" bolt. The strap the bolt goes through is bent and almost broken off of the tube. Anyone have one of these line up tools? It is tool #7402. I could pay shipping both ways.
I doubt you'll find anyone here who has that tool. I don't, and I've worked on more TWs than I care to count. We had one at the dealership I used to work at, and I always used it whenever I had that pipe off.
I suspect a dealership would be the only place you would find it, and even that will be no sure bet, as I bet most of them have lost or thrown them away by now.
Some careful measurements with a straightedge and a ruler should get the same result. Lube the tip of that thing up good with Vaseline before assembly so that it slides in easy.
I have had a DP apart twice and didn't encounter a need for any special tools. I think that they are mainly to speed work up, something that I am not interested in, LOL.
