2000 thermostat
jimNtx
New User
Is it the 2000 thermostat the same for both the 3 and 4 cylinders??
Need to replace one on my '62 4-banger. Appears current thermos is stuck open since water temp tops out at 130 degrees.
THANKS
According to the parts site, the part numbers are the same for these three thermostats on both the 3 and 4 cylinder 2000 models:
168 degree thermostat - originally D8NN8575AA superseded by 83913835
172 degree thermostat - D8NN8575CA
188 degree thermostat - D8NN8575BA
The two below are 180 degree and are only listed for the 4 cylinder models, one for gasoline models only and the other for diesel and kerosene models:
180 degree gasoline only - 86508396
180 degree - diesel & kerosene - C4NN8575A
