860 condenser bad - who makes a reliable brand?
Went through the carb and distributor, and checked everything at least twice for blockages, wrong adjustments or spacing
etc, and the condenser was the culprit. Who makes a RELIABLE condenser for this 6 volt system?
I've never had any trouble with new condensers. I've bought dozens of kits from Herschel parts, A&I parts, Tisco. I personally try to stay away from any electrical parts from NAPA.
(quoted from post at 17:17:13 05/10/20) Went through the carb and distributor, and checked everything at least twice for blockages, wrong adjustments or spacing
ell, if you found the condenser was the culprit, it must mean that you found a good one. There is your answer & why don't you share it with all of us?
Well yes, this condenser (probably bought from a farm store) works for now, but so did the last one until it didn't, in the middle of a job.
What I am looking for is a RELIABLE part.
Yep, Blue Streak is most folks choice. I've had a 1952 8N and a 1956 860 for 20+ years and they are great tractors, and I work on them to keep them running at their best.
Blue Streak fail also I tell folks to use the old one are stash it where you can find it cuzz you are gonna need it...
The only hope to finding a good one is if you run across NOS parts.
