Good evening,
I ve got a decent tractor that I d like to restore and continue to use on my small acreage.
This last week it started off as replacing the rear main seal, now I m completely rebuilding the engine and I m very tempted to go through the whole thing including paint.
What would be the correct gold paint code?
I m probably going to go through the soft parts in the transmission if I can find all of them and from the looks of it I should find a better/new input shaft and torque limiting clutch, any recommendations for the trans parts?
I ve been in the rear portion of trans to replace a seal and I changed a thrust washer to bring clearances back into spec. So I m not new to the difficulty of this trans.
Thanks,
Curt
Thanks,
Curt
