randy.zellers
New User
I purchased a 641 about two years ago, and the hydraulics have always had a bit of an issue. They work, but the lift won't begin to raise until I'm more than halfway up the range of the slider on the control handle. It also jumps or bounces, which I'm assuming is from a leak somewhere in the lift itself. Could both of these issues be part of the same problem, or is there some way to set the lift handle differently to adjust it? The only reason I ask this is that the leveler in the back had been put on upside down from the man who had it before me, so I just want to check and see if there had been other adjustments to be made.
