Jeremiah3000
title states it, it always clicks, has a new solenoid, i cleaned the ground cable, and attachment at tractor. Also has new battery, both cables and terminals are in great shape. I believe I'm having a charging issue. The alternator puts out 17 volts on large wire and 14.4 volts on smaller (at alternator), but I'm not getting that at battery, only 12.2 (I just put a new battery). Is there something like a regulator in between thats not allowing charge voltage to battery? I checked all fussed, and a couple were blown (have no idea what they went to). Tractor runs great, only has 930 hours. Its an 1988, 2810 diesel. 3 position ignition switch. Can't figure out how to get blinkers on either. Replaced those bulbs, light switch is just a pull knob and appears to only turn on the work light for the 3 pt work area. Am I missing something for the blinkers too? They are single wire, plan to remove, a d clean where they bolt to maybe help ground, otherwise still have no clue how to turn them on.
