Jubilee distributer problems
Well you know where the brass came from, either the rotor edge, or the buttons in the cap. Which is it? And why did you open it? Is something not working?
(quoted from post at 18:48:20 05/07/20) I got new cap and rotor but doesn"t fit right. It leaves brass chips under the cap.
Any ideas?
Sounds odd, if you remove the cap check for side play in the dist shaft.
There is a little spring clip that fits over the flat side of the distributor shaft, under the rotor. Did that get lost?
(quoted from post at 21:48:20 05/07/20) I got new cap and rotor but doesn"t fit right. It leaves brass chips under the cap.
Any ideas?
ust cover & gasket present? I believe they raised the cap a bit.
