Some of you may remember helping me out some time ago with identifying and trying to get my tractor running (again). I have recently begun working on it again (still not running). I have put a new starter, electronic ignition, battery, plugs/wires, rebuilt the carburetor, ignition... I have so many other questions to try and figure my mess out, but here is today's question: what is the correct starter solenoid to be using on this tractor? It has a solenoid mounted to the side of the battery tray. My limited understanding of starter solenoids is that some are grounded through their base and some aren't? This tractor has been converted to a 12 v system. However, whoever did so bastardized the wiring, including removing the safety starter switch from the setup. I ask about the solenoid, because sometimes when I try to crank it up, the starter get stuck ON, even when I turn the key back and even remove the key. I have to disconnect the battery in order to stop the starter. Any suggestions?
Thanks!
Thanks!
