Jubilee /8N transmissions
MHF35
New User
1-Do Jubilee and 8N transmissions the same length ?
2- Is it possible to install a 8N transmission (late 1952) in a Jubilee ? Need a spacer between the transmission and rear end ?
Thanks
? finally found answers in archives : https://forums.yesterdaystractors.com/viewtopic.php?t=1293580&highlight=jubilee++transmissions
"Jubilee trans. 3 inches longer, bolt pattern doesn't align, separated oil compartments".
and : "Not an interchange. The bellhousing will not line up with his engine. The rear of the trans with bolt even with the knocked case but the hydraulics might be hard to reroute".
MHF35
