Company Logo Shop Now
Order Ford 4000 Parts Online
Ford 4000? Need help identifying.
MarTanMan
05-05-2020 09:48:39
I will soon be putting a clutch in what I believe to be a Ford 4000, I have the model number, production code, and serial # from the tractor located on the flywheel housing behind the starter. Problem is the model number doesn t match any info I ve found on Oaktree Ford Tractors page. Numbers from top to bottom
7B23B
7C9
B835066
MarTanMan
05-05-2020 15:32:13
 Re: Ford 4000? Need help identifying. in reply to MarTanMan, 05-05-2020 09:48:39
Ok I ll check there thank you.
MarTanMan
05-05-2020 15:31:14
thanks, I will check on the left side and try to get some decent pictures. The decal under the hood is missing unfortunately.
Sean in PA
05-05-2020 12:42:54
That's an early Basildon domestic serial number.
The 7B23B and 7C9 both look like date codes. 7B23B is February 23 1967 and 7C9 is March 9 1967, so the transmission was probably assembled on February 23 and the tractor was probably assembled on March 9.
The model number may be on the left side as Ultradog said, or it may be up in the rough part of the casting above the numbers you already found. You can also check for the foil sticker on the under side of the right side hood panel to see if the numbers might be there. Once you've been a member for a few days and have 10 posts or more you can post pictures, and those might be able to help us to help you determine what it is if you can't find the model number.
Ultradog MN
05-05-2020 11:03:09
I think the B in the serial # means it came from England. So the model number won't be on the right side of the tractor where they usually are.
Look in the same area on the left side for some numbers and post those.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: DEARBORN SIDE DELIVERY RAKE CAN BE REPAIRED AND belly mount MOWER FOR PARTS ONLY.. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
