Help! Ford 3000 Construction tractor?
Gailej
New User
I am looking at, what I think is a Ford 3000. The seller said it was originally yellow and a construction series. The serial number does not match anything I know of and local shops dont know. Please help. I attached the numbers I found! On a side note, he said literally overnight the clutch started going bad. It now engages way up on the foot lever and before it was engaging way down. The adjustment on the lever is adjusted as far as I can. Pressure plate stuck overnight?[/b]
They did not come through. This site does not let you post pictures until you have around 10 posts to try to avoid spammers. Can you type in the numbers you found?
