801 Carburetor
baydog1
Hello hope everyone is doing well. I have a 801 that is having some Carburetor issues. I want to buy a rebuild kit for it but I'm having trouble finding the part
number on the carb. It's a Marvel-Schebler carb. Can anyone tell me where to find the part number? The carb is red so I'm not sure if the paint is covering the
number or I just can't find it.
Thanks
Scotty
There should be a tag rivetted to the side as shown below on my 1957 TSX-706 (assuming they didn't change with the 801 series). It is kind of teardrop-shaped. You can make out a 57 on mine but the TSX706 is there as well if you look closely.
Hello Andy. Thanks for the help. You are right on the money for part number location. The paint was covering the numbers and the tag is missing. My carb doesn't have the bigger brass adjustment screw on the top but it does have the low speed air mixture screw. The high speed adjuster is on the bottom of the bowl. As far as I know this is the original carb but the part number isn't like yours. My part number is kinda hard to make out but from what I can tell it's 227 458. Not sure if it's supposed to be more numbers in the middle where I put the space or not. Do you know if these numbers are my part numbers to use to find a rebuild kit? I've tried to attach a few pictures of the carb, the carb part# and the serial number of the tractor. Thanks for your help Andy.
Scotty
Hey, it looks just like the one in the parts book CONN-9510-G. This crosses to a TSX-813. The Ford Major Carb Repair Kit is listed as CAPN-9590-B but that's the old number. Just shop for a kit for the TSX-813.
<img src =https://i.postimg.cc/qRgYVbCn/For801-Carb-A.jpg>
<img src =https://i.postimg.cc/XqbwcX3J/For801-Carb-B.jpg>
