youngin
I am looking for some parts on a 7600 and
having trouble. Mainly the idler gear at
the pump. The gear is part# D9NN883AA, but
the gear is fine I need the bushing and
can't find a number. This is the first
ford driveline I have worked on. I called
All States and found some stuff. Other
things would be.
81879096 PTO drive hub is pretty loose on
the shaft. Normal?
C9NN7049C retainer output shaft. seem to
be some of these aftermarket.
EONN7R036AB direct drive hub. Current one
is cracked.
C9NN7R035A. Direct drive carrier.
Expensive part. Current one has the end of
the splines smashed making it hard to
remove Direct drive clutches. I could
maybe clean these up and use it again.
Acceptable?
Thanks.
The part description for part #D9NN883AA is "gear and bushing", so it looks like you need to buy the gear to get the bushing. But that part number has been superseded by part number 83919059, and the description for that is simply "gear" and doesn't mention a bushing, so maybe the replacement part number doesn't use one? In either case you'll have to buy the gear. But even the superseded part number may no longer be available new.
