Ultradog MN
- Location
- Twin Cities
My tractor is leaking engine oil from somewhere around the side mounted hydraulic pump. This is the gear type pump with the filter on it. I'm certain it is engine oil (color) and I do have to add oil to the engine on occasion.
It's hard to see where the leak is coming from but it seems to be getting worse.
The bolts that attach the pump are tight.
Before I pull the pump off I wonder if there's a place that's known to leak - other than the gasket.
Any ideas?
Thanks
Any ideas?
Thanks
