I have an 850 acquired from a family member. It has been almost completely rebuilt but has a few issues. It s gas and has the 5spd 2 stage clutch. The clutch is new. The tractor was rebuilt and parked under a shelter for about 3 years.
Clutch: pedal is about 6 inches off the step. Pedal has a mile of free travel above it s resting position. Both stages work. Shifts through gears easily and smoothly. Has some release bearing noise with pedal out and goes away when pedal is pressed. When driving, there s a loud (competes with exhaust) grinding/scrubbing noise that goes away when clutch is pressed in. Seems to vary with load.
Lift: lift lever works but most lift arm travel seems to be in the upper area of lever travel. When driving with lift up, draft lever in "position", or horizontal, the lift will float up and down.
Any help with this?
Any help with this?
